Re: WD9 Parts info
Posted by Roger in Iowa on May 02, 2008 at 16:26:47 from (69.18.26.97):
In Reply to: Re: WD9 Parts info posted by glennster on May 02, 2008 at 14:25:43:
Guys, thanks for the responses.
The spring is actually supposed to be on the linkages behind the carb but attached to the block.
Also, in the carb bowl itself there is a cam that only lets gas in while the diesel/gas lever is in the diesel position. That seems in error. Shouldn't it let in gas when in gas position?
I have an OM but it doesn't give enough detail.
e-mail is open.
Thanks,
Roger in Iowa
