Re: IPTO
Posted by Patrick Martin on May 02, 2008 at 22:13:00 from (64.154.26.250):
In Reply to: IPTO posted by Patrick Martin on May 02, 2008 at 21:29:03:
Thank you very much Chadd! I was worried and needed that bit of reassurance. :D
So basically what you are saying is that I need to make sure that before any sort of stop the baler needs to run out and there is no amount of hay left for the pickup to suck into the machine.
Kick it out of gear and let it run out if I bog or if I need to stop then do the same or run in between the windrows but do not disconnect the power from the PTO until the machine clears itself.
Correct? :wink:
