Posted by ih560 on May 02, 2008 at 22:18:05 from (204.118.68.33):
In Reply to: IPTO posted by Patrick Martin on May 02, 2008 at 21:29:03:
As far as I know a Super M does not even have an IPTO which means Independent Power Take Off. The IPTO is driven off the Pressure Plate instead of the clutch plate like the input shaft. The IPTO shaft is hollow and the input shaft runs through the center of it and into the clutch plate. It is designed this way so that you have power to the IPTO shaft at all times while the engine is running, even when the clutch is depressed. This was first implemented on the Super M-TA and was not available on the Super M. You could fit a Super M-TA IPTO shaft into a Super M but you would need the rest of the back half of the Super M-TA as well as the pressure plate from a super M-TA.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
