Re: C Farmall steering
Posted by Steven f/AZ on May 03, 2008 at 07:58:39 from (24.121.155.84):
In Reply to: C Farmall steering posted by CT8N on May 03, 2008 at 07:34:23:
Have you taken it apart to see what condition the key is in?
Even if the slot for the key is a bit slopped out, I've had good luck taking an oversized key and grinding it down to fit tight in whatever is left.
If you are going to drill a hole, make sure to get it the proper size and use a roll pin/spring pin that fits tight. A bolt won't fit tight enough and will soon be sloppy again.
