Re: Front front wheel bearing
Posted by IaGary on May 03, 2008 at 09:10:48 from (67.55.192.138):
In Reply to: Front front wheel bearing posted by Jay Snyder on May 03, 2008 at 08:55:26:
I use bearing race drivers (Check the link below). They fit right inside the race and you can whack on the race hard and not worry about maring or breaking the race.
Next best thing is a brass punch and hammer.
Make sure the race is going down straight.
With the race drivers they will go down straight cause you are hitting in the middle.
Gary
