Need bolt torque values for Super M
Posted by CenTexFarmall on May 03, 2008 at 21:27:22 from (172.130.18.88):
Finally topping the hill on the Super M. New bearing s bushings and seals and close her up!
However, I've figured out that IT doesn't have bolt torque values for some of the stuff I need.
I'm looking for bolt torque for: Ring gear and carrier bolts, bull gear bolts, pinion shaft bearing retainer bolts and inner axle bearing retaining plate bolts.
None of these are marked as such but did IH use grade 5 on these things?
