Re: Also need advice on Ring and Pinion setting
Posted by ihc49 on May 03, 2008 at 22:38:18 from (216.123.197.147):
In Reply to: Also need advice on Ring and Pinion setting posted by CenTexFarmall on May 03, 2008 at 22:01:56:
your right you should have got the backlash setting and a pattern, because it has to be set the same as it was.probably best to go the way it was with original shims.if you have too much lash you will hear a clunk from for. to rev. but were talking excesive. a .002 greater shouldnt matter. better that than the howl.if the pattern is good go with it.one more reminder ,new brgs. need a preload.
