Re: Farmall A leaky axle
Posted by Rootsy on May 04, 2008 at 05:50:44 from (70.8.219.193):
In Reply to: Farmall A leaky axle posted by RJV on May 04, 2008 at 02:58:10:
5 quarts in the rear end w/o PTO and 1 3/4 Pints in each final drive.
Believe you add a quart to the rearend if you have a PTO.
If the rearend is leaking then it is the diff support seals. If it is leaking near the brake bands (especially the right side) and not coming out of the weep hole near the rearend then the top final drive seal is leaking.
