Re: Also need advice on Ring and Pinion setting
Posted by trucker40 on May 04, 2008 at 09:21:15 from (70.240.148.62):
In Reply to: Also need advice on Ring and Pinion setting posted by CenTexFarmall on May 03, 2008 at 22:01:56:
You want your pattern in the middle of your tooth.You dont want it too close to the ends or the edge.Then you want about,I think,9 thousandths backlash.Hopefully somebody thats done this a lot will answer.I never did it on a farm tractor,just big trucks.You need a dial indicator and I cant remember what you set backlash at since its been a lot of years since I did it.I think it was 7-10 thousandths.If you use used parts you can have a little more backlash.In my opinion you should reshim the ring and pinion.Others might say different,but I think with having it apart to put in bearings you might as well set it right too.It might work out that it sets right if you put the same shims back in,and it wouldnt hurt to try it like that,but if its not right I would try and get it as close as I could.
