Posted by Coax on May 04, 2008 at 09:47:02 from (99.204.30.7):
First the stats,"58"240U w/a char-lynn P/S Unit. I Replaced the seals on the Steering wheel side of the pump about a Year ago when I rebuilt her,and it didn't give me any problems.I did notice that the bearing surface of the shaft in contact w/ the seal was pretty pitted and corroded. So I cleaned it up w/ emery cloth and put it back together.Well it worked for awhile,(8mo.)But now its leaking pretty good.Question? Can I put a Speedy Sleeve over the damaged Shaft and replace the seal again? Has anybody done this w/ success? Thanks! :oops:
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
