Posted by K-Mo on May 04, 2008 at 11:48:40 from (65.169.189.2):
In Reply to: CHAR-LYNN Leak posted by Coax on May 04, 2008 at 09:47:02:
I have a 240U. I had success with a"Quad Ring" from Force America. It's like a double o'ring. Also, make sure you have no air in your hydraulic system. I had a loader on it that would leak down causing air in the system. The quad ring took care of 95% on my leak and removing the loader took care of the rest. I also used a quad ring on my Case 630 with success.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
