Posted by Randy-IA on May 04, 2008 at 13:14:39 from (207.177.83.70):
In Reply to: Re: Tranny noise in M posted by CenTexFarmall on May 04, 2008 at 07:01:08:
Thanks for the vote of confidence ! Yup , It's real annoying because I was borrowing the neighbors shop and was in a hurry to get it done since it was dragging on longer than I expected it to . I was feeling guilty about using his space when I knew he needed it for his own projects . So I cut corners and lost . The bad part is that I used high tack on all the gaskets that will need to be removed again so that will be another $100 or so for gaskets .:( Advice - DON'T use anything on the gaskets till you know you have it right ! Save some cash . Both axles , cover , bull pinion o-rings and pinion end gaskets will need replacing when I open it back up . Maybe not the o-rings . The old tractor is a money pit these days since this morning I went out and saw the rear rim was broken on the right side and the tube was showing through the rot from the liquid . Now I need a good rim . I'm getting a little discouraged about this old tractor so I'm going to leave it for a while and concentrate on things that need doing around here . Good Luck with your's ! ...Randy
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
