Re: Tranny noise in M
Posted by Randy-IA on May 04, 2008 at 14:22:36 from (207.177.83.70):
In Reply to: Re: Tranny noise in M posted by John M on May 04, 2008 at 13:37:34:
Yup , So maybe after a another decade of hard use it'll start to tone down :) . I don't know when the 9-speed was installed or how worn out the tractor was when it was installed so that makes sense . The bearings were pretty rust pitted and loose when I took it apart as was most everything in the case including the gears . So that's most likely it . They are worn in to each other with a different contact area than they have now . I'm not going back into it till this fall anyway so time will tell if it wants to start to quiet down in the interim . Thanks for bringing that up ! ...Randy
