Re: farmall h steering shaft
Posted by Mike CA on May 04, 2008 at 14:52:35 from (67.181.230.232):
In Reply to: farmall h steering shaft posted by poorfarmall 1 on May 04, 2008 at 14:47:49:
poorfarmall 1 said: iam taking the head off , the steering shaft looks to be in way . do you take out gears in front? going to remove raditor + clean & throw away shutters they dont seem to behooked to anything thanks for any help
First of all, please don't throw away the shutters. There are restorers who could probably use them, and those kinds of things are hard to come by these days.
As far as the shaft removal, unscrew the cap on the front of the top bolster and drain the oil. At the u-joint just behind the instruments undo and remove the bolt that is holding the turning key in place. Then all you have to do is unscrew the shaft to disengage the worm gear at the front. Then you can slip the shaft all the way out.
