Don't forgot to take out the woodruff key before you try to pass the shaft throught the center support. It won't fit through.
Do you really need to remove the steering shaft to pull the head on an H? I pulled heads on my M and 450 Diesel without touching the shaft. In fact in helped me with the diesel. That head is so heavy that the only way I could lift it was to lay my chest over the steering shaft, pull straight up, and set the head on the studs.
Of course when you pull the steering shaft, that would be a good time to check the condition of the bearing and pull the cover on the gearbox and check the tightness of the castellated nut.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
