Re: O/T lawnmower has gas coming out exhaust
Posted by Steven f/AZ on May 04, 2008 at 15:26:02 from (24.121.155.84):
In Reply to: O/T lawnmower has gas coming out exhaust posted by Mike CA on May 04, 2008 at 14:09:19:
3 things needed for a running engine: fuel, spark, and compression.
You obviously have fuel. Does the engine have reasonable compression?
I'm going to guess that it didn't spark like it should have (or not at all).
First thing I would do is pull the spark plug and have a look at the condition. If it's questionable, replace with a new one. Can always put the new one on the wire and set it against the metal portion of the engine - pull the rope and look for spark...
I've had coils go bad suddenly on lawnmowers before, causing a no spark condition. Hopefully you just need a new plug.
