Mike CA said: (quoted from post at 14:09:19 05/04/08) When I tried to start my lawnmower this afternoon it wouldn't catch. I pulled the choke back as I've always done and gave it a couple swift pulls, but nothing. After about 10 pulls I noticed gas was coming out of the exhaust. So I'm guessing I've flooded it?
Mike: I'd say you flooded it if you pulled it 10 times with the choke on and gas is pouring out the exhaust. In fact, it might be said you drowned it. Pull the spark plug. Turn off the choke. Open the throttle fully. Pull it through about 15 times. Dry the plug off. Check for spark by laying the plug against the block with the wire reconnected to it. If you get a good blue spark then reinstall plug. Make sure the kill switch or lanyard is in the run position (if it has such). Try starting about 4 cranks with no choke. If that does not work, then choke it with two pulls. Then if still not started, turn choke off and again crank without choke.
If that does not work, then check fuel quality. Make sure fuel is fresh.
If that does not work, then junk lawnmower and buy a Woods belly mower for the family Farmall H. Mow with H, thus proving to wife once and for all that getting H was a great idea.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
