Posted by Parke1 on May 04, 2008 at 16:46:28 from (98.27.206.191):
Hey guys,
Well, apparently my float is stuck on my new H. This is a 1951. I started it up and ran if for a while today, then after I shut it off I had fuel running out of the air inlet (my air tube is currently off being painted). I assume this means a stuck float.
I tried to take the carb off, but I must be missing something here. I took the two nuts off the top studs coming off the intake manifold, then removed the two screws from the governor tube, but I still can't get the carb off. I can't lower it due to the coolant drain tube directly underneath the carb, and I can't slide it rearward since it's still on the two top studs on the manifold.
Do I have to unscrew the coolant drain tube from the block? I hope not, since it's going to be a bear to get a pipe wrench on that sucker.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
