Re: Priming M oil pump
Posted by El Toro on May 05, 2008 at 06:19:03 from (205.188.116.73):
In Reply to: Priming M oil pump posted by Oil Pump on May 05, 2008 at 04:42:34:
Set the pump in a clean container of engine oil and twist the drive gear until the pump is primed and then install on the engine. We had a pressure vessel so that we could force engine oil
thru the engine until it showed oil pressure on the gauge then we would make the engine start.
Hal
