Re: Priming M oil pump
Posted by Janicholson on May 05, 2008 at 07:48:40 from (199.17.6.122):
In Reply to: Priming M oil pump posted by Oil Pump on May 05, 2008 at 04:42:34:
Do as El Toro indicates, To go beyond the oil pump only, use a squirt/pump oil can to fill the galleries into the oil pressure gauge hole. (several cans may be needed to fill filter and all passages. but it is cheap, and works. JimN
