Re: glow plug blowout!
Posted by mkirsch on May 05, 2008 at 07:53:39 from (64.80.108.52):
In Reply to: glow plug blowout! posted by B Griffin on May 05, 2008 at 03:47:58:
As you probably were aware, I don't think you're supposed to use ether with glow plugs.
All four plugs were damaged from the (repeated?) ether use.
Unless plugs you've changed AFTER ether was used are now failing, you have one more plug to change for sure.
