Re: Farmall 140 valve cover retaining bolts, what type?
Posted by Hugh Mackay on May 05, 2008 at 16:05:40 from (216.208.58.99):
In Reply to: Farmall 140 valve cover retaining bolts, what type? posted by rdragoo on May 05, 2008 at 08:59:10:
rdragoo: I saw your question this morning, been 4 years since I had the valve cover off my 140. I don't remember anything special about those bolts, however I intended to look today and forgot. I know my SA and 130 have bolts in the head with a threaded top and 2 nuts hold the valve cover down. I believe my 140 is the same. I do know if you draw those down too tight you will recess top of cover around bolts. If that has happened they will leak.
