Re: 966 differtial bearing replace how to
Posted by Jim Kreis on May 05, 2008 at 19:24:38 from (209.173.254.189):
In Reply to: Re: 966 differtial bearing replace how to posted by Edpap on May 05, 2008 at 18:36:08:
thanks ED ya it is the outer bearing. it is on the diff side is it all right to pull the shaft out it hits on the bearing how do you get it to come have not try ed to hard pull it out it come till it hits the bearing on the gear inner bearing. takeing the bull shaft out it will not throw things off in side there if it is taken out will it go back with out line up probles . how would one go about takeing off the inner bearing thank you some much for your help if you were closer to WA state and a hunter you would be welcome to hunt turkeys and white tail bucks turkeys are takeing over are area thanks
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
