Re: 966 differtial bearing replace how to
Posted by Edpap on May 05, 2008 at 18:36:08 from (74.33.240.66):
In Reply to: 966 differtial bearing replace how to posted by Jim Kreis on May 05, 2008 at 18:15:00:
Hi Jim,
sounds like you are looking at the outer bull pinion shaft bearing the diff. bearing is farther in. I would replace both the bearing and the race. I bet it is on the diff lock side, they always go bad. If you have an IT manual it will tell you how to set the bearing preload. If you don't have a manual I would buy one they are about $30 bucks and they are well worth the money.
I did a 1066 last month both sides and it was no big deal. be sure to set that preload (endplay) and I always reseal the brake pistons and replace the outer oring on the housing.
Also you are right you can't pull that shaft out without removing the inner bearing it willnot clear the bull gear
Good luck Ed
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
