Re: Video of a problem that plagues me....
Posted by Calif. Farmall on May 05, 2008 at 19:37:19 from (67.142.130.49):
In Reply to: Video of a problem that plagues me.... posted by Patrick Martin on May 05, 2008 at 18:18:07:
WOW!- Thats a lot of blow by. Did you have the problem before you changed the rings? Did you put each ring into the cylinder by itself and check the gap before installing them on the piston? It's possible you have the wrong rings, sleeves that are so worn or out of round that the rings won't seal. Now if your rings are correct and the cylinders checked out good you might check the compression on each cyl. and see if it's up to par. Look at each spark plug too see if one looks different or fouled. Also might try disconnecting one plug at a time too check if one cyl causes more blow by than others. It looks like a lot of pressure coming out, and my guess is if the problem wasn't there before the old rings had worn into the cyls egg shaped and the new rings may take years to seat in or never. Hope this gives you a few ideas, Dan.
