Re: Video of a problem that plagues me....
Posted by MN Scott on May 05, 2008 at 20:15:11 from (206.9.216.42):
In Reply to: Video of a problem that plagues me.... posted by Patrick Martin on May 05, 2008 at 18:18:07:
Did you do half a job and put new rings on worn pistons in worn sleeves? If you did new rings are a near perfect circle. The old sleeves and pistons are most likely not a perfect circle. My opinion, if you want a qualitity job the ring and piston, sleeve assemblys have to be replaced as a set so everything is tight.
