Re: Video of a problem that plagues me....
Posted by Patrick Martin on May 05, 2008 at 20:30:44 from (64.154.26.250):
In Reply to: Video of a problem that plagues me.... posted by MN Scott on May 05, 2008 at 20:15:11:
MN Scott said: (quoted from post at 20:15:11 05/05/08) Did you do half a job and put new rings on worn pistons in worn sleeves? If you did new rings are a near perfect circle. The old sleeves and pistons are most likely not a perfect circle. My opinion, if you want a qualitity job the ring and piston, sleeve assemblys have to be replaced as a set so everything is tight.
I did but I wouldn't really call it half a job or put it like that. A part can be worn but within tolerable specs as given in the manual and is perfectly useable.
While not fully dismissing the possibility, I do doubt it is the piston/rings. I was wondering if it might be a leaking exhaust valve guide or something and if any of you have had similar issues? Still...maybe the rings/sleeves/pistons?
This is my very first sleeved engine rebuild. Are sleeves prone to egging? :?:
