Re: Re: H Head vent tube missing
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by FL on March 10, 2000 at 06:01:18 from (152.3.34.218):
In Reply to: Re: H Head vent tube missing posted by Farmer Bob on March 09, 2000 at 23:33:09:
I got the fitting out OK; no problem with the tube - it's missing. (The one with the hole is the one from inside the head cover.) After removing the fitting I was able to pull the head off fairly easily. All four piston heads are covered with a black deposit. The valves have a light coating of black but otherwise look pretty good. Next is dropping the oil pan, which will be full of oil since the plug is frozen tight and will need to be drilled out. Sounds like fun. From the sound I get when I spin the engine with the rear wheel, there's something going on with the #1 cylinder, maybe a broken piston ring.
Post A Followup
: Re: Re: Re: H Head vent tube missing
Today's Featured Article - History of the Cockshutt Tractor - by Danny Bowes (Dsl). The son of a very successful Toronto and Brantford, Ontario merchant, and himself quite an entreprenuer, James G. Cockshutt opened a business called the Brantford Plow Works in 1877. In 1882, the business was incorporated to become the Cockshutt Plow Company. Along with quality built equipment, expedious demand and expansion made Cockshutt Plow Works the leader in the tillage tools sector of the farm equipment industry by the 1920's. ... [Read Article]
