Re: H Head vent tube missing
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Farmer Bob on March 09, 2000 at 23:33:09 from (207.227.187.21):
In Reply to: H Head vent tube missing posted by Frog Level on March 09, 2000 at 06:22:08:
If you're going to remove the fitting go easy on it. Those original fitting are soft and you chance schmooshing it. Use a 6 point box-end wrench on it and go slow. Replacements are probably available but they are different than your standard brass fitting found in the normal places today. The small hole near the top bend was most likely caused by it rubbing on the under side of the hood. and, like the other posts say, it vents the oil fumes from the head back down into the oilbath air cleaner.
Post A Followup
: Re: Re: H Head vent tube missing
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
