The clutch disk can be changed on a Super M, but not the pressure plate.
You need to pull out the belly pump first. Then the whole bottom of the tractor is wide open with plenty of space.
Once you get the belly pump out of the way, you will find that the input shaft has a coupler in it. Remove the coupler, and unbolt the pressure plate. You can then wiggle the shaft out.
It's all pretty tricky, but it is possible. It's a lot easier on a plain M, and you can get the pressure plate out to replace it as well.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
