Re: E85
Posted by Bob on May 06, 2008 at 18:25:56 from (69.178.228.68):
In Reply to: Re: E85 posted by garytomaszewski on May 06, 2008 at 14:31:14:
1.) I wasn't specifically referring to you.
2.) I agree it's hard to achieve EPA "numbers" in the real world. HOWEVER, as I said before, when looking at gasoline and ethanol EPA mileage for the same vehicle, a reduction of 30%, more or less, is common. Once again, I ask... do you think the EPA "skews" the two tests of the SAME model of vehicle to make ethanol look bad???
  • Re: E85 Jon Hagen 20:43:59 05/06/08 (1)
    • Re: E85 Thack 21:11:44 05/06/08 (0)
  • Re: E85 garytomaszewski 20:23:31 05/06/08 (0)
