Re: F-12 Plow Pictures
Posted by ET on May 07, 2008 at 05:21:16 from (134.179.104.132):
In Reply to: F-12 Plow Pictures posted by Tom Fleming on May 07, 2008 at 03:06:47:
The colter and clamp are the same as a pull behind plow of the same vintage. Do you have an operators manuel for that plow? I have a plow like that on my F12 and it is a sweet plowing rig, but I would like to find out what the wheel spacing should be when its set up for a 16" bottom.
