Posted by riverbend on May 07, 2008 at 19:38:58 from (208.160.33.254):
In Reply to: Oil For new M engine posted by Break-in on May 07, 2008 at 19:10:06:
Any good detergent oil will work fine. Diesel rated oil might be better for the cam and lifters. Change the oil and filter after a few hours. Change them again after another 20 or so.
Work the tractor while you are breaking it in. Start with easy loads and work your way up to a heavy load over a few hours.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
