Re: Farmall 200 steering gear
Posted by gene bender on May 08, 2008 at 18:06:39 from (67.55.226.69):
In Reply to: Farmall 200 steering gear posted by Cody Butts on May 08, 2008 at 13:49:57:
You should get an I$T manual. You need to block the front so you can remove the wheels and then the axle. Then you can take the steering sector apart and rebush and maybe the bearings need replacing. New parts to rebuild the steering sector will run around 50 bucks. When done with new seals and bushings it will be like new again.
