Re: Which engine kit super A
Posted by Bill Byford on May 08, 2008 at 19:27:07 from (74.192.83.189):
In Reply to: Re: Which engine kit super A posted by Hugh Mackay on May 08, 2008 at 02:37:04:
Thanks Hal & Hugh.There is room for the longer sleeve in this block.I want Tisco Parts.Will go with 123 cu,3&1/8 bore.More Questions,Should block #354898R1 have a water pump? Will this overbore cause overheating?Head gasket info calls for with/wo water pump,what"s the difference?Maybe I need to order the head set for a 113cu & sleeve kit for 123cu & get the gasket with the larger water ports?This is a work tractor. thanks Bill
Today's Featured Article - Ford Super Dexta - by Anthony West. The rusty blue tractor caught my eye as my truck zipped by the farm implement business. It looked so fornlorn amongst the lineup of newer equipment. But it was just the right size for my small farm. I stopped in and asked the proprietor for further information. "It's a 64 Ford Super Dexta", he said. "It's a tough little tractor, although it's a hard starter being a diesel and all." He did manage to get it running, compliments of a can of ether. Once started it putted along pretty good. It ... [Read Article]
