Re: IHC 460-560
Posted by RN on May 09, 2008 at 00:45:02 from (69.129.253.251):
In Reply to: IHC 460-560 posted by :RIVIR on May 08, 2008 at 20:03:29:
double check bolt pattern at flywheel end - possible difference in 560 the 460 so might not fit. 460 was discussed in puller forum and bolt pattern noted as fittable to 300, Hs but not M and 560 drives unless dual pattern block was found. 560 and M blocks not to fit H drive which 460 developed from. RN
