Re: Farmall MV questions
Posted by CNKS on May 09, 2008 at 17:11:52 from (216.144.104.128):
In Reply to: Farmall MV questions posted by matt06br on May 09, 2008 at 15:24:07:
If it has a wide front and dropped rear axles it is an MV. If it has a single front and dropped axles it is a cotton harvester tractor, the serial tag should rule that out. The engine is the same as the M or W6, so it won't have different markings. I haven't ever seen one up close. Just drive it and listen for strange noises from the transmission and final drives. Every thing else is no different from any other 60+ year old tractor.
