Re: 1066 diesel timeing
Posted by w.g. on May 10, 2008 at 04:21:36 from (205.188.116.73):
In Reply to: 1066 diesel timeing posted by wildchild55719 on May 09, 2008 at 22:53:02:
do you know if you first had the pump tdc or 180 off when you puled it the first time?
