Re: 1066 diesel timeing
Posted by wildchild55719 on May 10, 2008 at 07:10:59 from (69.19.14.38):
In Reply to: Re: 1066 diesel timeing posted by w.g. on May 10, 2008 at 04:21:36:
i thought i had the pump set right when i pull it.
but when i checked the timeing marks on the flywheel they weren't even close so i turned the flywheel till i saw timeing mark A then about 18 degrees past that was four .... marks does this still sound like 180 Degrees off. should i try bleeding the injector line first most of the new engine i have worked on will self purge ???
