Re: Farmall Super C that smokes
Posted by Janicholson on May 10, 2008 at 08:36:21 from (199.17.6.122):
In Reply to: Farmall Super C that smokes posted by it smokes on May 10, 2008 at 08:19:29:
Uniform wear results in uniform compression. Stuck rings, or worn cylinders and rings can be at fault and still have compression.
Pulling the head will allow clear assessment of the ring wear in the cylinder. There is probably a ridge where the top ring stops its upward travel. If this ridge is able to be felt easily with a fingernail, it is time for new sleeves and pistons. Kits are available on this site, and appear as good as any. The sleeves are wet sleeves, which means they can be removed easily without special tools or pullers. Check the archives for information on installeing wet sleeves. JimN
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
