Re: 656 w/single remote lugs engine in 1 position only?
Posted by Owen Aaland on May 10, 2008 at 15:04:16 from (65.165.246.39):
In Reply to: 656 w/single remote lugs engine in 1 position only? posted by Janicholson on May 10, 2008 at 08:40:42:
Janicholson said: (quoted from post at 08:40:42 05/10/08) Check the hydraulic "switch" on the end of the valve opposite the lever. This switch controls single acting, or double acting. It rotates in place, and has a sheet metal clip over a roll pin to limit its travel. I think CCW is double acting. JimN
The 656 uses the newer valves like the 806. There is no switch to turn. Instead there is a rod that loops around to limit the travel of the valve spool to block out the float position. If you do not have pressure in the lever forward position you may be going to far and getting into the float position.
