Posted by Roger46 on May 10, 2008 at 15:35:40 from (69.58.159.96):
In Reply to: Farmall 450 IPTO posted by Stan in WI on May 10, 2008 at 07:43:39:
I just put mine back in a 350. What position do you have the engagement lever in? If it is in the disengage position the input shaft may just turn as you turn the unit so it will never line up unless you are lucky. If the lever has the PTO engaged you can turn the PTO shaft and turn the input shaft to help spline alignment (Turns hard through the planetary gear system). They are heavy units and amazingly complex for what they do as I just rebuilt mine. Roger
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
