Posted by Hugh Mackay on May 10, 2008 at 18:32:40 from (209.226.106.88):
In Reply to: Gasoline Additives posted by MarkA on May 10, 2008 at 18:16:24:
Mark: Lead was only ever required for high performance, high rpm engines, your Farmalls are neither. You've just been wasting your money.
I have a Farmall 130, probably close to 10,000 hours, 3/4 of that without lead. I also had a Farmall 300, probably has 25,000 hours on it by now, I know it's on it's 6th set of pistons and sleeves. It too probably had 3/4 of it's hours without lead. Since lead protected the valves, I can tell you this, bottom end of the engine will long be worn out before the head gives problems. Since you'll problbly do the head at every rebuild, not much point in spending money on lead. Besides once after no lead, my 300 had a piston and sleeve kit installed and the head required no rebuild. In that case the head out lasted two piston and sleeve kits.
SAVE YOUR MONEY, you got better things to use it for.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
