Re: A cylinder 2 and 3 not firing
Posted by 1fortyfanatic on May 11, 2008 at 16:15:37 from (4.228.9.165):
In Reply to: Re: A cylinder 2 and 3 not firing posted by 658834 on May 11, 2008 at 14:02:10:
Just FYI, you might want to consider checking around the manifold while it is running to see if the gasket there is possibly a problem. If the manifold gasket on an A is like my 123ci Farmall 140, then the manifold has intake and exhaust side by side. And if the gasket has blown between almost any two of the ports, then you could be getting exhaust in the intake of the neighboring cylinder, in which case, valves will not function properly, and plugs would probably look dry. Be advised though, that if you pull the manifold, you'll probably lose one or both of the old gaskets, so order new ones before you ever pull it. Case / IH dealers can order these gaskets for you, and have the shipped to your house in 3-5 days.
Good Luck
Dave
Today's Featured Article - Talk of the Town: Modern Diesel Fuel in an Old Tractor - by Staff. This interestin discussion is from the Tractor Talk Discussion Forum. Remember that safety is your first priority - make sure you know what you are doing before attempting a potentially dangerous activity! ... [Read Article]
