Re: A cylinder 2 and 3 not firing
Posted by francoisc27 on May 11, 2008 at 16:22:36 from (68.159.112.4):
In Reply to: Re: A cylinder 2 and 3 not firing posted by 658834 on May 11, 2008 at 16:18:26:
El Toro said: (quoted from post at 18:47:22 05/11/08) Take a look in the radiator and see there's bubbles when the engine is at an idle. Did you adjust all the valves to .017" cold? Hal
I'll check the bubble thing, but no I haven't touched the valves yet other than when I first got the thing I could'nt get compression on cyl #1 an I found out the pushrod fell out from under the rocker arm. I just pushed it back in and had compression again.....
Francois
