Re: Super M Seal Removal?
Posted by Nebraska kirk on May 11, 2008 at 16:29:31 from (98.16.169.114):
In Reply to: Re: Super M Seal Removal? posted by Smith1000 on May 11, 2008 at 10:19:37:
If you can't remove the seal retainer at this point then I would say that you will have to remove the large steel plate. But first you will have to come up with some way to support the engine because, as you say, "The side rails would then be free from the rear of the engine."
There is no specific torque listed for those bolts. Just use reccomended torque for the size and grade of bolts in question.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
