Mowers aren't like tillage implements in that they just don't load the tractor all that much. If it will pull it across the yard, it will pull it in the field.
I've cut thousands of acres of heavy alfalfa with a 9' swath using a H.
Hook 'er up and go. The only problem you're gonna have is that lift cylinder; gotta rig 'er for one-way use with the H.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
