Farmall small 4cyl oil pump question.?
Posted by t.r.y. on May 13, 2008 at 01:41:28 from (205.188.116.73):
hello I'm working on rebuilding a 123 and the oil pump flange at the top the cast aluminium piece is warped around the part the sticks out at the flange. It doesn't look like it was sealing at all. it still had good oil pressure but maybe not quite the volume of oil because of bleeding out at the top of the pick up where it bolts to the pump housing. What do you reccommend on doing? Is there enough room to surface grind flat again and reuse? or can I buy a new one some where?? thanks for the help in advance. T
