Re: Farmall small 4cyl oil pump question.?
Posted by TractormanNC on May 13, 2008 at 04:36:48 from (209.42.180.233):
In Reply to: Farmall small 4cyl oil pump question.? posted by t.r.y. on May 13, 2008 at 01:41:28:
Common problem with these engines. Have taken as much as .014 off one to get it flat. Cheap way to do it is a piece of plate glass and sandpaper (about 200 grit I think). They usually warp most on the pressure side. Make a reinforcing bar out of 1/8 x 3/4 flat steel and use the existing bolts to bolt it to the cover on the pressure side.
