Re: engine dies when mower blades engaged ond moving
Posted by El Toro on May 13, 2008 at 03:52:09 from (64.12.116.73):
In Reply to: engine dies when mower blades engaged ond moving posted by Chris Gould on May 12, 2008 at 13:56:48:
You should remove the gas line at the carburetor and see if there's a good flow of gas from the gas line. Hold a clean container to catch the gas. If there's good flow and not just a trickle pull the fitting in the caburetor that the gas line was connected to. There's a screen behind that fitting that may be clogged with dirt & rust. If it's not dirty your carburetor needs a good cleaning and all jets blown out. Make sure the float is set at the right height for your tractor. Hal
